Sagem Samsung Toshiba Sony which is the best tv
S
stephenJ
hi,can u help whats the picture like from sky on the dlp range 45 50 56 .Going to buy one of these new models but unsure of the picture ,seen hd in comet looks fab ,but only a few chanels going to be available in hd or should I Buy plasma or lcd set, look forward to any advice thanks
Grobnic
Sagem
K
kmhtkmhtkmht
I own a Sagem and until the engineer boy comes and fixes my set, I will love Samsung more.
NOISE ON HDTV! Can you believe that?! Only a Sagem can do that... 1080i HDTV stuff with Noise ALL over it.
sprattgraham
Established Member
Do you use a satellite box or a PC for 1080i
S
stephenJ
hi which samsung model ? but if the noise problem is fixed on your sagem would you still go for the samsung model ,what model is your sagem. Are you happy with the picture through sky or analog thanks for your reply
sprattgraham
Established Member
What PC resolution are you using
C
Chumpy
None of the above - go and audition the sets before you part with that amount of money.
M
Marksurry
I agree with Chumpy. Look at all the sets before parting with your cash. I went out for a Sagem and ended up walking away with a very nice Samsung SP46L6HX, which in my eyes blew the opposition away. Don;t be afraid to make the sales people work for their money ;)
K
kmhtkmhtkmht
Native Resolution. I know what I am doing especially when it comes to PCs...
The Sagem is a Noisy Noisy.
Snap
The picture is unprocessed in native resolution - the noise is coming only from the source. I have no problems with my Sagem showing SD via DVI from PC
sprattgraham
Established Member
If you can only see the problem when watching 1080i and its fine on the Windows Desktop, watching DVD’s then there is nothing wrong with the Sagem.
It’s a problem with your software/codec
the_pauley
Sagem and Samsung are deffo the leaders of the DLP pack, but, always audition and make up your own mind.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
