H
HowardMoonjazz
Hi.
Bought a SAGEM ITD64 Freeview box off ebay no manual or box, told it works 100%
Anyway got today, tried it out this evening, cannot get any reception what
so ever.
Flicking through with handset i get the following come up on screen.
Problem in signal reception
No data availble for this channel
Please check your areial antenna
Check cable on your box input then check your box
Tried everything, but i did I've come across something called Installation code on screen, do i need to put in a code number to make it work?
Anyone got any ideas?
I have emailed the seller, still awaiting responce.
so ever.
