Sagem HTD 501 sound but no picture
gaz911
Hi the problem is the indicator goes green but now there is no picture. All sound is ok . When switched on it displays "stereo"in black lettering on a grey background about 6" x 4" at the bottom of the screen, but then nothing else on any of the inputs.There are no lights diplayed except the green .
The bulb is lighting up for a short time then switching off so I assume its not the bulb although i have been advised its a weak bulb ?
any help appreciated gents:lease:
gaz911
So the Tv has been sitting in the dining room for a couple of months , any advice before I throw it out:lease:
new bulb ? fuse ? counter ?
MikeDX
Hey gaz Mine has just started doing exactly the same thing. I'm going to try and get a cheap bulb. When i turn the tv on, i get "stereo" on grey/black and then just black screen. It can only be the lamp or controller. Some places are charging up to £500 for just the lamp!! I will let you know how i get on Mike
Spielberg, Shyamalan, Aronofsky, Chazelle, Eddie Murphy and Mel Gibson - all the latest movies
