Sagem HDT 501
Blacksheep
Joined
May 20, 2008
Messages
5
Reaction score
Points
3
I got the ballast conversion kit to change the lamp and have fitted it. The TV now appears dead, no LED lights at all. I'm pretty sure I didn'd disconnect anything by mistake. Any Ideas
It's still Blacksheep. I discovered I needed to refit the front protection panel before it would power up. However, new bulb not working. I have tried to do the 'timer reset' with the resistor wire - any tips and how can you tell if it has worked.
Hi Blacksheep.ive fitted same ballast kit 6 month ago.Got mine to work by soldering the two wires on the back of the count down chip. In the bulb housing .Been working fine since.Hope this helps thanks .chugs.
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
