Sagem HD56 Picture Quality
Discussion in 'General TV Discussions Forum' started by Fusewire, Jul 18, 2005.
  1. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    Hello everybody, been reading the forum for a bit now as I am after a new HDTV (Just registered today and this is my first post :smashin: ), I saw the Sagem HD56 in Comet (again) this week and I have decided that this is the one for me. However one thing worries me, the picture on the analogue input (BBC1) had quite a bit of blockyness to it, the assistant then put on the HD demo which was a lot better although nowhere near the picture quality that was on the HD45, is this because the set is not set up properly ? :lease:
    Thanks in advance, also could anyone recommend a decent surround sound system for £200-£300 that would go with it.
  2. n00b
    n00b
    Nov 27, 2004
    315
    +17
    i've found the hd quality and the picture quality from sky to be exactly the same as the d45 :confused: however i sometimes notice the weird gladiator face type blur (its been discussed before on the tosh 46" set) on low quality channels - but this is rare.
  3. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    Thanks nOOB :thumbsup: , I suspect that the one in comet has not been set up very well, why do they do this ?? Seems crazy to me - you would think that they would want the picture to look as good as possible to sell more of them (The plasmas were even worse BTW).
    Anyway thanks for the reply :smashin: you have put my mind at rest that with a couple of hours of tinkering I will get an excellant picture out of it. :clap:
