Sagem - HD through PC
Discussion in 'Televisions' started by irishboy, Aug 11, 2005.
  1. irishboy
    irishboy
    Hi all.
    I want to use the High Def funcionality on my Sagem HD-D45 through my PC.
    Can anyone tell me what sort of Cables etc I need and where to get them? Is there anything else I need to do?
    Thanks,
    Mickey
  2. HSC
    HSC
    Nov 23, 2004
    1,901
    63
    Coventry
    +139
    there are 2 pc inputs on that set - so either a DVI or a VGA cable will give you high def.
    check the manual for which resolutions the set supports on the PC input (ideally 1280x720)
    cables are available at all good computer stores (inc. internet) - check required lengths and dont go cheap...
  3. irishboy
    irishboy
    thanks mate! :)
