Sagem HD-D45 + PAP Question
blackwavesid
Had my HD D-45 since Feb but only tried playing with the PAP function recently. I'm unable to select AV5 and PC2 at the same time, with one selected the other doesn't appear as an option on the other half of the screen.
Has anybody else managed this and if so how?
Sid
blackwavesid
I did read the f manual (page 17) but there was no reference there as to specific sources being unavailable.
Snap
rigth, sorry.
you have old manual (i downloaded it from the SAGEM's site and compared it with mine).
I got new manual with my TV covering 45, 50 and 56 inch versions.
and it says that AV5 won't work with PC and DVI in PAP modes.
blackwavesid
Thanks for the update Snap :thumbsup:
Oh well, there goes my side by side DIV / component comparison. Have already tried it by switching sources but thought this may be more convenient.
Trending threads
