Sagem HD D45 owners.....
Discussion in 'General TV Discussions Forum' started by jonathan, Jul 8, 2005.
  1. jonathan
    jonathan
    Feb 8, 2002
    160
    19
    Kent
    Has anyone worked out how to get their set when first switched on, to auto-switch to the Sky feed instead of the internal analogue tuner? This is most annoying...........
  2. dog-man
    dog-man
    Oct 30, 2004
    141
    16
    Excuse my butting in here please.
    Can someone say if the teletext is whole screen or just a squar box in the centre of the screen?
    dog-man :hiya:
  3. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    teletext is a square box on the HD-D45 was on the 50 aswell.
    Why do you need to know.
  4. dog-man
    dog-man
    Oct 30, 2004
    141
    16
    Just curious. I prefer full screen teletext.
    I have a friend who has a huge crt tv and his teletext is full screen.
    On my 28 inch wide screen, it is only a square box in the middle and is difficult to read because it is so small.
    I am defniately going to get a Sagem HDD45 soon regardless.
    Hopefully, next week.
    dog-man :hiya:
  5. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    dogman :hiya:
    I didn't know anyone still used Teletex. :confused:
    I have full screen teletex but I have a Optoma set.
  6. mishmash
    mishmash
    May 23, 2005
    144
    Cornwall
    +9
    I would quite like to know the answer to this as well, however it does have a nice benefit. When ever the gf gets hold of the remote and tries to get Big Brother running she moans that there is No Signal on the TV and I tell her "That's because the sky satellite has a problem and there is no Big Brother on tonight" :D
  7. jonathan
    jonathan
    Feb 8, 2002
    160
    19
    Kent
    Anyone?
  8. PsychicLemur
    PsychicLemur
    Jan 5, 2005
    128
    If you have the Sagem connected directly to the Sky box via a fully wired SCART, then when you turn on the Sky box, the TV should either automatically turn on if it's in standby, to the correct channel, or just switch over to the right channel if it's already on.
    Also, if the TV is turned on automatically like this, it will go back into standby when you turn your Sky box off (unless you've changed channel manually since).
    This is with a Sky+ box, but should work the same for a standard Sky box. It also requires you to set INSTALL > SOURCES > MANAGER to AUTO in the TV's menu.
    Hope this helps...
  9. jonathan
    jonathan
    Feb 8, 2002
    160
    19
    Kent
    Thanks for the reply.
    I already have it set to auto in the manager menu, but hardly ever leave the set in standby mode. It is nearly always switched off, hence this annoying problem upon start-up everytime.
  10. n00b
    n00b
    Nov 27, 2004
    315
    +17
    hmmm auto switching does not seem to work for any of the 3 scarts on mine, but does work on dvi, weird :confused:
  11. PsychicLemur
    PsychicLemur
    Jan 5, 2005
    128
    Do you have:
    1. A fully wired SCART
    2. INSTALL > SOURCES > MANAGER set to AUTO in the TV menu
    3. Scart Control set to ON on your Sky box
  12. n00b
    n00b
    Nov 27, 2004
    315
    +17
    i live up to my name, i was using the wrong socket on sky box heh heh, still worked for picture though, just not switching. thanks lemur :smashin:
  13. dog-man
    dog-man
    Oct 30, 2004
    141
    16
    Does this set display NTSC source material in colour?
    The specs I have just read say Pal and Secam only, but I seem to recall reading elsewhere that it will also display NTSC.
    dog-man :lease:
  14. PsychicLemur
    PsychicLemur
    Jan 5, 2005
    128
    Of course it will - I don't think you can buy a TV now that won't...
    If it says PAL and SECAM, that will be what the tuner can handle as a broadcast; but plug an NTSC source in and it will work just fine.
  15. dog-man
    dog-man
    Oct 30, 2004
    141
    16
    OK, Great! Thanks.
    Mind made up now, I will get one when I can.
    :hiya:
