jonathan
Received my Axium today, and set about attaching the speakers (for everyday kids use). Now is it me or are they a pain to attach? A third hand would have been nice. Trying to squeeze the speaker toward the set to locate the holes while balancing the screw on the end of the driver, and preventing the whole set slipping off the a/v stand was not a great start. Also whilst one side is nicely flush with the top corner of the set, the other sits a bit proud (high - only a mill or two) and looks cheap & shoddy. Does anyone else have the same problem? I would try swapping them around but seeing as they should be identical I don't know if it's worth the agg.
Overall am happy with the set.
