Sagem HD-D45 & HDMI
Discussion in 'General TV Discussions Forum' started by Apollo11, Mar 10, 2005.
  1. Apollo11
    Apollo11
    Mar 14, 2004
    639
    2
    32
    Hadleigh, Suffolk
    +87
    Can anyone help with this query? I am about to order the Sagem HD-D45 and am hoping to connect it to my Pioneer DV868AVI Dvd player via HDMI. I note the sagem has DVI input only and the user manual for my Dvd player suggests there may be some compatibilliy issues. Has anyone on these forums used the DVI input on the Sagem for Dvd connection and if so, has it performed ok?
    All responses greatly appreciated.
    AVnut70
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,224
    103
    Nottingham
    +289
    You shouldn't have any problems connecting the HDMI output to the Sagem's DVI input with the appropriate cable, they're both HDCP devices so they should be OK. I know the're some issues regarding connecting HDMI to a non-HDCP compatible DVI device but this shouldn't be the case here.
  3. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +19
    DVI-D is close to HDMI without the sound. It will work fine with an adapter or better with a quality cable.
  4. Apollo11
    Apollo11
    Mar 14, 2004
    639
    2
    32
    Hadleigh, Suffolk
    +87
    Cheers for the help guys, I'll have a look for an adapter or suitable cable.
    AVnut70.
