Sagem HD-D45. BOX DIMENSIONS PLEASE
J
jerkyboy
Can someone please tell me how big ths Segam HD-D45 is when its in the box.
I might go and collect one from my local John Lewis but I am not sure if it will fit in my car !!.
Is it ok to lie the box on its side or does it have to be transported stood up ?.
Any help would be appreciated.
geordie_blerk
It depends how big your car is I suppose. Mine was delivered in a van and when it was stood on it's base it was a couple of inches between the roof of the van and the top of the box. If you have a big estate car the only way you could probably get it in is if you lay it flat and I've no idea if that woud be a good thing or not.
I couldn't tell exactly you how big the box is, although I would say it was about 6 inches more on all sides of the tv, if that makes sense.
It's surprisingly light as well btw.
n00b
you took the words outta my mouth jerky (actually i asked in another thread but nobody answered :p) btw i called my JL and they said it would take 2 weeks to deliver and i could not pick it up! which JL can you collect from?
J
jerkyboy
Thanks Bruce.
Are you happy with your Segem, any problems ?.
Similar threads
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
