sagem freeview question Tvuk Gold
Discussion in 'Freeview & YouView' started by millwalll, Dec 26, 2004.
  1. millwalll
    millwalll
    i got a sagem itd58g is there any way i can get more chanels without paying any more as i really want tvuk gold is there a way i can get this chanel or do i need to pay the 7.99 a month if so how do i get it as i thought they send u a card to put in your machine but i cant see a card slot for my box and it seem a bit silly to pay 7.99 month for only one chanel any help be realyl nice
  2. knoxville
    knoxville
    If you want to get top-up tv you need a box with a card slot in it- i suggest a Thomson as they are good quality and generally a good box
    Yes you have to pay the whole 7.99 a month even if you just want UKTV Gold.
    You have to pay extra for the 'you know what' channels
  3. donbren
    donbren
    Hi,can you help.i want to connect my dvd player into my tv,freeviewbox circuit,as the f/v box only has one scart socket ihave tried to use a 2 scart box extn but the screen is blank, eg iconnect the extn into the tv and then the leads from the dvd and f/v box into the 2 scart box extn. if i link the f/v box with a single scart lead to the tv all is ok,can you help.cheers don
  4. andyMallion
    andyMallion
    Hi Don I use the above which costs about £30. The gr8 thing is its active, electrically powered and determines automatically which 'scart' socket is in use
