SAGEM DLP D45S and the pc
Discussion in 'TVs' started by mojoicus, Sep 5, 2005.
  1. mojoicus
    mojoicus
    Feb 15, 2005
    89
    Hi sry to sound dumb im getting 1 of these very nice tvs delivered and fitted on Thursday
    What i need to know is what sort of dvi cable do i need to connect it from my pc graphics card to the tv
    + any tips online or otherwise were to get 1 from
    Mnay thx
    Steve
  2. mojoicus
    mojoicus
    Feb 15, 2005
    89
    Anyone please :)
  3. dunsters
    dunsters
    Mar 14, 2005
    303
    +7
    The first question is what sort of Graphics card are you using and does it have a DVI output. If so, it will a question of DVI-I (analogue and digital output) or DVI-D (digital only) cables (See the card spec). Buying a cable from an AV source (such as the people at TVCables http://www.tvcables.co.uk) is better than from a PC outlet as the Av source usually has better quality/shielded cables IMHO
    Cheers:hiya:
  4. Snap
    Snap
    Aug 7, 2005
    188
    Celle (Hannover)
    You need only DVI-D cable - 18 or 24 contacts. DVI-I wouldn't fit as it has 4 more connectors for analogue RGB.
  5. mojoicus
    mojoicus
    Feb 15, 2005
    89
    many thx
