Sagem DLP 45
Discussion in 'General TV Discussions Forum' started by stevenC, Mar 19, 2005.
  1. stevenC
    stevenC
    I took delivery of the new Sagem HDD45 yesterday and have coupled this with the new Yamaha speaker system YSP-1 and then the Denon 2910 to play NTSC format. Overall, this is a great mix and the quality I am receiving is just fantastic for both TV through Sky and DVD's.
    One good thing that came out of this was purchasing the stand that the Sagem is offered with, its an extrra 300 pounds but the Yamaha speaker fits perfectly into the top shelf and blends in with the system, you wold think its built for that.
    Picture quality is just super but we did use correct audio and DVI cables to enhance picture quality at all times. The choice was a Toshiba or the Sagem and pleased now we went for the Sagem.
    Steven
  2. skaps
    skaps
    Oct 31, 2004
    45
    how did you use the dvi lead, i mean what have you got it connected to? :hiya:
  3. Apollo11
    Apollo11
    Mar 14, 2004
    701
    2
    32
    Hadleigh, Suffolk
    +94
    Stevenc, I got my HD45 yesterday and cannot get it to work via hdmi, are you using an hdmi to dvi cable or an adapter at one end of an hdmi lead? This problem is driving me mad as I only bought the Sagem due to its HDMI capability!!
    Richard (AVnut70)
  4. pwrslide
    pwrslide
    have got my hd45 conected to a samsung hd745 with a dvi to dvi cable picture very good
  5. n00b
    n00b
    Nov 27, 2004
    317
    +17
    avnut i am using a hdmi to dvi cable with the S97 and it works fine with my d45, although i have a feeling the d45 will need to be swapped out soon because the spdif sockets have suddenly stopped doing passthrough :mad:
  6. Apollo11
    Apollo11
    Mar 14, 2004
    701
    2
    32
    Hadleigh, Suffolk
    +94
    nOOb, thanks for the reply, does you dvd player have to be connected to the HD45 to select enable HDMI in it's setup menu or can you select at any stage? Im trying to establish whether the cause of my problem is with the hd45 and my dvd player not communicating via hdmi (hopefully this can be sorted easilly)
    Richard.
    AVnut70 :eek:
