Sagem Axium Prog Scan Problems
Discussion in 'Projectors, Screens & Video Processors' started by Mike.Smith, Aug 7, 2004.
  1. Mike.Smith
    Mike.Smith
    I have a SAGEM AXIUM and DENON 500SD. WHEN I SWITCH THE DENON TO PROGRESSIVE MODE IT SPLITS THE SCREEN OF THE AXIUM IN 2 IE 2 IMAGES. WHAT IS THE PROBLEM? THE AXIUM DOES RECOGNISE A PROGRESSIVE IMAGE BUT THE SCREEN SPLITS
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    The problem is that the Sagem either needs to be told it's getting a progressive image and it needs to turn off it's own de-interlacing (menu setting somewhere)....or it doesn't support incoming progressive signals.
    Gordon
  3. Mike.Smith
    Mike.Smith
    Thanks. The SAGEM does support progressive scan - just cant understand why this is happening
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    Are you sure it supports progressive scan at 480p and 576p? It's a rear pro DLP device isn't it?
    The artefact you see is what happens when you send a progressive scan signal to a device which is expecting an interlaced signal. If it does support the resolutions you are sending then there must be a menu setting wrong.
    What sockets are you susing on the display and the dvd player?
    Gordon
