Sagem Axium Problem
Discussion in 'Desktop & Laptop Computers Forum' started by nutsak316, Sep 16, 2004.
  1. nutsak316
    nutsak316
    Hi guys,
    Hope you can help me...
    I have just had my shuttle delivered, but despite my best attempts I can't get the Axium to deliver a full screen image. All I get through the DVI is 4:3.
    Even when I select a widescreen resolution (1280x768), It just squeezes it into a 4:3 sized box on the TV. PLEASE HELP!!
    My graphics card is a Radeon 9800XT.
    I know that the native resolution is 1280x720. I also know that this resolution is not native to any graphics I know. So, my question is, how do I set the resolution to 1280x720???
    Thanks.
    Sakboy :lease:
  2. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Moving to HCPC's.
  3. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    if you do a search for PowerStrip and 1:1 pixel mapping on these forums you will get loads of advice :)
    stick with it - it will be worth it!
  4. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    Must be possible as Shuttle PCs are used in Comet to demonstrate the Sagem.
    Have a look on the Sagem website under Support.There is a reference to this problem on there though it is in French.This refers to Powerstrip as the solution.
    Sagem Helpline is also unusually helpful if you do not crack the problem.
    Best of luck.
    Aaln
  5. showcase
    showcase
    Hi can anyone help me
    i have the sagem axium 50", well i connected my pc to it through a dvi-d cable and can only get 4:3 picture!!!!!!!!!!!!!
    the confusing thing is, i had the sagem engineer in before i set up my pc cuz, the prob i had with the tv at that time, the picture was grainy around the writing and people on every sky digital channel, well sorted that out. he connected his pc to my sagem and he got full 16:9 pic............................
    i rang sagem and he suggested to download powerstrip, i cannot find the software anywhere and i'm not going to pay for it. the powerstrip website is under constraction for the past month!!!!!!!!!!!!!!!!!!!!!!
    the anoying thing is.... i have a radeon 9700 pro graphics, one of the best and i can use any resolution and hrtz, so what difference will power strip do???????????????????
    sorry about the essay, but had to explain
    can any1 help?
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    As David says in a post above, do a search for powerstrip on this forum and 1.1 pixel mapping, its all free (software and tons of advice).....
