Sagem Axium htd501 Help Needed Please!
Discussion in 'General TV Discussions Forum' started by ripley607, Jan 18, 2008.
  1. ripley607
    ripley607
    Dec 4, 2007
    15
    3
    Hi.
    Does anyone know how i could update the firmware for this Tv?.
    After reading loads on the net it seems i need at least version 61 before i could get a Hd resolution through component on Av6.
    At the moment, Av6 wont display any of the higher resolutions only SD & av7 shows HD but some of the screen on the right is missing or blank when using 720p.
    My set shows that im using software 51 which is presumably causing all these problems. anyone know where i can obtain the software & cable to upgrade this set?
    thanks.
    :lease:
  2. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    Try and contact Sagem and ask them to send the software and cable
  3. ripley607
    ripley607
    Dec 4, 2007
    15
    3
    I would if i could find a contact number or email address.
    it seems a support page of sagem that i found has neither.
    :confused:
  4. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    SAGEM AXIUM : 0 844 441 1299, I did have the CD and cable for this TV and year ago, didn't need it so got rid of it, they might say you need a tech but it's a load of rubbish you don't.
  5. ripley607
    ripley607
    Dec 4, 2007
    15
    3
    Thanks for the number, i will give em a ring sometime tomorrow.
    :thumbsup:
  6. Mr8K
    Mr8K
    Hi did you ever get the firmware CD & cable from Sagem.
    Just wondered as I have a unit with version 049 everything!
    cheers
    mr8k
  7. finch700
    finch700
    Hi guys, I got this TV given to me by my Nan and Grandad a few months ago, but can't get my PS3 to display correctly, even through using a component in AV6/7 etc, but my xbox 360 does and it displays great, but my wii wont let me select display in 720p, only 720i, and my ps3 will only let me select AV, not even 720i.
    after reading your discussion, can you help me to understand this firwire upgrade, as in how do I do it? and what is needed for it?
    Do you think that my consoles will work on it properly after I do this?
    I would really appreciate the help.
    - Chris.
