Sagem Axium HD56 and the yellow boxes on Sky
Discussion in 'General TV Discussions Forum' started by DVD Connoisseur, Sep 8, 2007.
  1. DVD Connoisseur
    DVD Connoisseur
    Had Sky+ installed today and I asked one of the engineers why the yellow on the Sky menu always looks a bit poor (noisy). We checked between RGB (signal is through great quality RGB lead) and PAL and there was no difference visible. The engineer recommended I play around with the settings for the television.
    Has anybody else found the menu screen noisy with yellows on the Sky menu? Is there a cure?
    Cheers!
  2. mray
    mray
    Feb 16, 2004
    2,777
    83
    London
    +235
    Are you sure he connected the leads the right way round? It sounds like you are getting a composite picture, because you should definitely see a difference when changing from pal to rgb on the Sky menu. I had a 56B and all three scarts were RGB enabled. Could he perhaps have used the VCR scart socket on the Sky box instead of the TV one?
    Hope this helps.
  3. DVD Connoisseur
    DVD Connoisseur
    That did the trick! Many thanks! :)
  4. mray
    mray
    Feb 16, 2004
    2,777
    83
    London
    +235
    No probs.:smashin:
