sagem axium hd-d56
Discussion in 'General TV Discussions Forum' started by steve666, Jun 11, 2009.
  1. steve666
    steve666
    Jun 11, 2009
    3
    can anyone help put a new bulb in tv but the colour is very poor shadows on certain colours tried to alter contrast etc but to no afect it is doing my head in be very greatfull if somebody could help:lease:
  2. DJACID
    DJACID
    Feb 29, 2008
    1,690
    London
    +148
  3. steve666
    steve666
    Jun 11, 2009
    3
    thanks will try this will let you know if it worked if not tv going out of window:(
  4. DJACID
    DJACID
    Feb 29, 2008
    1,690
    London
    +148
    also check you tv, sky, cable wires make sure there are all fine,
    and check other av inputs on the back....
  5. steve666
    steve666
    Jun 11, 2009
    3
    cleaned colour wheel and lens tv working spot on thanks:thumbsup:
  6. smondey
    smondey
    Oct 10, 2009
    2
    Hi wondering if anyone can help ? :confused:
    Have a Sagem axium hd 56 which has packed up.
    watching happily till a small pop noise and then complete shut down.
    Currently can get nothing from the unit, no stand by light, nothing !
    Have checked power lead and is all ok but no power within the unit ...anyone have any ideas ? :lease:
  7. Paul3
    Paul3
    Nov 26, 2009
    3
    Hi there
    In the bulb case there is a small fuse ,it is a 1 amp fuse replace this and see if that helps , the fuse is only 50p- £1.00 :thumbsup:
  8. jacajfr
    jacajfr
    Oct 2, 2009
    10
    3
    Sorry but the bulb case fuse won't help, it is used to reset the lamp age counter to zero when replacing lamp. And is blown on purpose when reset is done...if you change it, your lamp age counter will be false and will prevent warning you before lamp failure.
    You could have a main power supply failure and no fuse is directly replacable.:(
