SAGEM AXIUM HD-D45S G4T - Lamp/Bulb
Discussion in 'General TV Discussions Forum' started by Eallin, Dec 20, 2006.
  1. Eallin
    Eallin
    Nov 20, 2004
    290
    Nottinghamshire
    +3
  2. HellraiserUK
    HellraiserUK
    Nov 13, 2005
    229
    +10
    Yep, that's the bulb in question - you need to remove the existing one from the cradle it sits in but that should be fairly straightforward. Best to get some of those latex gloves as you don't want to touch the bulb directly, this will seriously impair its life (similar issue to handling headlamp bulbs, the grease on your fingers causes issues).
    Go here and scroll down:-
    http://translate.google.com/translate?u=http%3A//www.cesky-spolek.com/DLP/Lampe-Ampoule-Thomson-Sagem-DLP.php&langpair=fr|en&hl=fr&ie=UTF-8&oe=UTF-8&prev=/language_tools
    Hellraiser............>
  3. fizzgog
    fizzgog
    Feb 6, 2006
    1,305
    2
    63
    wirral
    +112
    i always thought that when replacing the bulb and not the housing, you had to disable the counter and therefore run the risk of the new bulb exploding.
    i was wondering if someone could tell me whether this would allow the counter to be reset and would then stop usage of the new bulb after 8000 hours:
    http://66.249.93.104/translate_c?hl=fr&ie=UTF-8&oe=UTF-8&langpair=fr%7Cen&u=http://www.moovika.com/boutique2/product_info.php%3Fproducts_id%3D46%26osCsid%3Dfc06ced496c6eb94f697b7d5e1310a15&prev=/language_tools
    seems too good to be true.
    pete
    [edit] if so, will any glass fuse of the same rating work such as:
    http://cgi.ebay.co.uk/10-x-500mA-slow-blow-glass-fuse-20mm-40ma-to-16a-also_W0QQitemZ130044335742QQihZ003QQcategoryZ26205QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
  4. Eallin
    Eallin
    Nov 20, 2004
    290
    Nottinghamshire
    +3
    Excellent thanks :thumbsup:
    Can't get the link to open at work, but will try when home later. Just hope it does the trick.
    Ed.
