Sagem Axium Colour Problem
Discussion in 'TVs' started by MartinFXDX, Dec 13, 2004.
  1. MartinFXDX
    MartinFXDX
    Jun 6, 2004
    325
    +4
    Could anyone please give me any advice on a problem with my new Axium?
    I had it delivered today and it works fine off air and through SVideo input but the component feeds (progressive and interlaced) have a strange colour shift whereby blue shows as green and red and brown are scarlet. I have tried 2 DVD players with the same result.
    In my rush to get the Axium set up have I missed a setting or is it a fault?
    Any suggestions welcome (within reason!)
    Martin
  2. MartinFXDX
    MartinFXDX
    Jun 6, 2004
    325
    +4
    Well, I may have sorted it. I changed the component cable to three runs of analogue interconnects (co-ax construction but no idea whether 75 ohms) and I've got the right colour! :rolleyes:
    Any ideas how or why? The cable is a 4m Precious Metals SilverTech RGB/Component.
    Martin
  3. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    Make Sure You Are Using Av7 For Progressive And Av6 For Interlaced.
    Alan
  4. MartinFXDX
    MartinFXDX
    Jun 6, 2004
    325
    +4
    Yep.
    Repeated putting the component cable back on. Result same colour problem. Put analogue cable back and colour correct again.
    Cable seems ok but......!
    Martin
