Sagem Axium 50 switches on from standby
Discussion in 'General TV Discussions Forum' started by tealandsilver, Jan 18, 2005.
  1. tealandsilver
    tealandsilver
    Nov 29, 2004
    14
    3
    Hi, my 1 month old Sagem Axium switches itself on when left on standby. This appears to happen after a few hours. In a few posts I have noticed others mentioning that this happens to their sets also, but only with a Skyplus box connected. In my case, I've only got a freeview digibox. Has any-one actually found a way to stop this occurring, short of switching the power off at the rocker switch or mains? Should I be concerned?
    regards
    David
  2. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Havent had no trouble with mine but I must admit I dont leave it in standby unless I will we switching it on again within the next 10 mins or so because I am very tight and like to save electricty :)
    Use the rocker switch or call sagem to get engineeer out check your software also I am on 0.62
  3. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    this is not a fault on a particular set, but a design issue. Optomas do it as well. One of the scart control signal (dont know which one but probably SCART CONTROL) wakes up the tv when in standby mode. Have I resolved the issue? answer: I switch mine off when not in use.
  4. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    Yes it is the scart control doing this.It will occur for example if the STB box is left on a channel that is switching from 16:9 to 4:3.
    Easiest way to stop this is to snip the wire on pin 8 in the scart lead.
    Do a search on Google for a scart wiring diagram.It is not difficult to identify the correct wire to cut
    Alan.
  5. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    My optoma rd65 switches on when i power up my dvd player or xbox. A good feature as it puts the right channel/input on for tha device. It never switches on without me first switching on a device.
  6. tealandsilver
    tealandsilver
    Nov 29, 2004
    14
    3
    Thanks for all the replies. My software version is 62 also. I could understand the freeview digibox switching the set on as Alan mentions but it is also on standby when the tv switchon occurs. I'm timing the switch on now to get a feel for whether it occurs at the same time interval every time or not. After that I'll disconnect the freeview box for a period and confirm that it occurs due to the scart control and when it does I'll get the snips out........ :suicide: :eek:
  7. tealandsilver
    tealandsilver
    Nov 29, 2004
    14
    3
    Update: TV took about 4 hours before it switched itself on today. This compares with about two hours previously. I'm away out to the garage to look for my snips..........
