Sagem Axium 50" owners
Discussion in 'General TV Discussions Forum' started by evolution400, Mar 9, 2005.
  1. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Hi guys just decided to feed terestrial into the axium via RF as an extra to Sky so I can record one watch the other I have yet to setup an arial but the actual picture of the snow is too far over to the right about 2 inches of blackness can be seen on the left side this doesn't change until u select scope mode anyone else experienced this ?
    Just wondering if its a fault or not.
  2. digitize
    digitize
    I have the same sort of setup - Freeview box and RF terrestial feed. I have no problems at all. Wife and kids have been watching via RF and they're happy.
    One thing I wanted to ask... The software version of my Sagem is 0062. I haven't had any problems so far, but do I need to contact Sagem to upgrade to 0063? How do these upgrades work anyway. Would it be better to request for a cable and CD, and do it DIY using PC/laptop?
    Thanks.
    technology works this way - immitate, integrate, innovate...
  3. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Must be a fault then but strange it only occurs on the RF channel.
    I havent had an ugrade myself mate so not sure but I will enquire when I contact sagem support if you like.
  4. digitize
    digitize
    Please. Thanks. If they can provide CD and cable, and easy enough to do it, then I think it's better that way. I assume you already know how to check the software version?
  5. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    I had the software update send out to me on CD with a cable.
    Took about 30 Min to update.
  6. digitize
    digitize
    Might do it that way then... Do you know if there's a difference between 62 & 63? I haven't had any problems so far, but is it worth upgrading from 62 to 63?
  7. JohnWin
    JohnWin
    Feb 9, 2005
    207
    +9
    Hi Digitize
    According to Sagem there is 'no real difference' between 062 and 063. For what its worth, IMO if it aint broke ....
