Sagem 45 or Samsung 46 ???
Discussion in 'General TV Discussions Forum' started by kingtj, Jul 23, 2005.
  1. kingtj
    kingtj
    Mar 11, 2005
    372
    Coventry
    +10
    Finally decided to take the plunge. I'am looking at these 2 sets,
    Sagem HDD45 & Samsung SP46L6HX.
    I've seen the Sagem at comet and was quite impressed but they did'nt have the Samsung.
    Any help would be greatfully received
  2. mr_sockochris
    mr_sockochris
    Dec 19, 2001
    123
    Ware, Hertfordshire, England
    +5
    I'm torn between these 2 too. I'm leaning towards the Samsung because of the HDMI input, but it only has the one Component input while the Sagem has 2. Do Component switch boxes exist anywhere? I use an RGB SCART switcher with my current TV but i've never seen a Component equivalent. :confused:
  3. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    Maplins sell a manual switcher with 9 phono in and 3 out.Being non electronic it works in either direction.
    I use it to switch component.Works well and it's cheap.
  4. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    The Sagem 45 and 56 only has one Component input which does Interlaced and progressive. The old 50" had two component inputs.
    The inputs on the new Sagem models are 3x-Scart 1x-Component 1x-VGA 2x-S-Video 2x-Composite 1x-DVI The 45 also has SPDIF In and Out.
  5. mr_sockochris
    mr_sockochris
    Dec 19, 2001
    123
    +5
    Thanks, the Samsung it is then. I do alot of gaming so the extra component input would have been a big plus point, but if they both have one then I think i'll go with the Samsung. Just to make sure, DLP's are better than LCD's for gaming, right?
  6. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    DLP's are superb for games console especially a modded xbox running with the hd leads. You can get 4 way electronic switchers from various places or you could put the component inputs into an av amp and let that do the switching.
  7. mr_sockochris
    mr_sockochris
    Dec 19, 2001
    123
    +5
    Mine doesn't have any component inputs in it though :( (it's a Marantz SR4200) Can anyone recommend a good switcher? Do I need a specifc component switcher, or would component leads simply work on a normal composite switcher (putting the component red/blue/green cables in the red/white/yellow inputs)?
    Please forgive my total lack of knowledge :p
  8. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    Sorry to go slightly off topic but... ;) Is a loss in signal quality experianced using a component switch? - I'm thinking I may be forced to use the inbuilt one in the Denon 550SD
  9. bigfinger
    bigfinger
    im in exactly the same boat i cant make my mind up between the
    sagem HDD45S / HDD45EU 1789.46 (inc VAT)
    Samsung - SP46L6HX @ £1,210.00 (Inc VAT)
    there is quite a price diff as you can see so im leaning towards the samsung but cant find anywhere to actually see it in the flesh so if anyone has had experience of these i would appreciate some input too.
  10. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    You should start to see the Samsung at your local Currys now.
  11. mr_sockochris
    mr_sockochris
    Dec 19, 2001
    123
    +5
    My local Curry's have both, the Sagem was even set up with som HD media playing on it, it looked super sweet :D
  12. bigfinger
    bigfinger
    and ?? which was better did the satin finish on the sagem put you off or not ?
  13. mr_sockochris
    mr_sockochris
    Dec 19, 2001
    123
    +5
    What the TV looks like is the absolute last thing I worry about when buying a TV, but I thought the Sagem looked quite nice actually. Unfortunatly, the Sagem is a little bit too much for me so I went with the Samsung.
  14. bigfinger
    bigfinger
    ? i am reffering to the satin finish on the screen itself not on the case :rotfl:
  15. mr_sockochris
    mr_sockochris
    Dec 19, 2001
    123
    +5
    Oh right :p I didn't even notice it on the Sagem, but the lighting conditions were far better than they were near the Samsung TV so it's hard to compare.
  16. bigfinger
    bigfinger
    ok thats good info thanks... :smashin:
  17. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    Easter Ross, Scotland
    +251
    This was one factor that made me decide on the Samsung rather than the Sagem. The Sagem definately had a slight sparkly look to the picture because of the anti-reflective coating. No such effect on the Samsung, just a deep black background.
  18. roone
    roone
    Mar 31, 2005
    76
    9
    East Grinstead
    I havent seen the Sammy, but I've had my Sagem for about 6 months now and have been very happy with it. Excellent piece of kit.
  19. bogie
    bogie
    Jul 21, 2005
    72
    I am on my 2nd Sagem, soon to be 3rd or swap to Samsung this time.
    1st Sagem had loud whistle from the power supply
    2nd Sagem has a kind of snowy effect to the picture even on comp from DVD which is very annoying.
    Not sure if I should give the Sagem another chance, I am thinking not.
  20. soni
    soni
    Oct 22, 2004
    557
    Kent
    I would go for a Sammy :smashin: - although i haven't watched the HD-D45 for any length of time, i have read a review that mentions dot crawl and fizzing over horizontal panning - sounds like the Tosh's 'characteristic' is rearing its ugly head again :eek:
  21. showcase
    showcase
    hey go for a sagem 56" and its cheaper then the 50" u bought, well it depends how much u paid for it in the first place. my sagen 50" broke, so was deciding to get 56", but i also seen the samsung 50". so still deciding as the room is being built, as soon taht is done i will have made up my mind :D
    the the bigger the better :D well for me anyway
