Safety/recommendation for PV500 stand setup
Discussion in 'Home Cinema Buying & Building' started by tutu, Sep 14, 2005.
  1. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    I've decided to do a little re-organising of my setup. Basically I have the 42PV4500 with CAB and would like to fit my amp on the bottom shelf.
    At the moment I have my VCR/DVD recorder on the middle shelf, with Sky and Canton centre on top shelf.
    My problem is that the amp is simply to tall to fit. I can move the middle shelf higher but then the VCR/DVD recorder does not fit.
    So would it be safe to either:
    a) remove the plastic feet off the amp (saving a cm or 2)
    b) remove the middle shelf, and put the VCR/DVD recorder on top of the amp on the bottom shelf
    c) remove the top shelf, and put the Sky/Canton on top of the VCR/DVD on the middle shelf?
    I've lost the setup instructions for max Kg. - and I am not sure about those vent things... :D
  2. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    I have gone for b for now :p
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    make sure the amp doesn't get too hot like that, you'll have to have a rethink if it does!
  4. Lionheart
    Lionheart
    There is another way...a dedicated hifi stand...but of course that means more money
