Safe to install US 2.90 software on a UK AVR300 ?
Discussion in 'AV Receivers & Amplifiers' started by bedders, Sep 25, 2004.
Tags:
  1. bedders
    bedders
    Apr 29, 2003
    224
    UK
    Does anyone know whether it is safe to install this update on a UK AVR300 ?
    http://www.aslgroup.com/arcam/AVR300Software/AVR300Software.htm
    Yes i've rung my Arcam dealer and all they can do for me is ring Arcam to get the latest CD, then have me bring in my AVR300 and wait a few days while they perform the update.
    I'm a computer engineer and have already loaded several s/w and drive updates on my DV88Plus so am happy with the procedure, and the instructions are clear enough for most.
    Thanks in advance for everyones help.
    Nik
  2. Shaka
    Shaka
    Jul 26, 2004
    757
    Glasgow
    +39
    Yes it is. I updated about a week ago. Very easy to do, just follow the simple instructions and fo the updates in the right order (there are 2 steps).
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,572
    Edinburgh
    +1,268
    I have spoken to Arcam about this who confirmed there is only one version of the software and they are not region specific.
