Tell us more about your rig.
I'll try. I knew next to nothing about the inside of a computer when I started this project, I've been learning on the job. Read up, buy a part. Read up, buy another... Now it is all done I wanted to know about temps. I'm very encouraged by your responses.
I have an Antec Fusion. I swapped the regular fans for some Noctua NF-S12s. They are pretty awesome. 3 pin though. The Zalman Fanmate2 can control them between 4-13volts. I don't really know what that means but basically between silent and mildly irritating.
Most of my media is on a Western Digital Green 2TB while the system drive is a suspension mounted WD2500BEKT 250GB. I figured the laptop drive would be good for heat but it spins at 7200 rpm so in theory I shouldn't lose out on performance.
The CPU is a AMD Athlon IIx4 620, overkill, but every once in a while I need to do some encoding and I'd rather it not take days. Reading around, cores seemed to be the most important thing for this. I was worried about the quad but a really helpful poster here, Williamw11, assured me it would be o.k. I max the fans which usually I run silent and it has been going well so far I think. I noticed there is also an option to disable some cores in the BIOS but I haven't needed to yet.
It runs passively cooled with a Scythe Mini Ninja. If heat ever becomes a problem while encoding a guess I could get the CPU fan out of the cupboard. I usually line up some files for encoding then do it while I'm at work so noise isn't an issue in that regard. I haven't needed to yet.
My Gigabyte GA880gm-USB3 handles the graphics on board. I don't game and all my movies are DVD atm. A few files might be 1080 downloads, I can't remember, but I haven't run into a file it couldn't play faultlessly yet.
430W Nexus Value-430 True Power PSU (unbelievably quiet, I haven't heard a peep from it) and 2gb of DDR3ram and I think that's about it.
6 fans? Good god what kind of monster are you running?
No mate. That is just the way SpeedFan displays its info. The fans are 3pin so I don't think it can monitor them anyway, irritatingly neither can the mobo. I thought it was me but people are saying the same thing on the gigabyte forums. If you look closely it say 0RPM when in fact both of them are on. As long as the temps are o.k. I figured I don't really need to know how fast they are spinning.
