Sacd
L
Len
Ok So I now have a player capable of playing SACD. The sample discs sound very fine.... But where the hell can I get SACD's that have the kind of music you may want to listen to. PLAY have a very limited choice and don't seem to have added anything new for ages. I believe some Rolling Stones remastered stuff is due out... but where can I buy?
Does anyone actually own any decent SACD discs?
Come on... I'd like to hear from you.
T
Tejpal
SACDs are very limited...
I cant tell alot of difference between CD and SACD.
The future is MP3 (or similar eg. WMA).. why wont manufacturers start developing good MP3 cd players !!! :mad: :mad:
Y
Yummy Fur
Tejpal, I think you may have to compare CD's & DVD's on system with sufficent resolution to highlight the differences between the two, which IMHO are vast.....
I think MP3 is is a 'convenience' format, it's OK, but certainly not the highest of Fi......... There are quite a few DVD players that now replay MP3. I think 'good MP3 players' is probably a contradiction in terms...... :D
Yummy Fur
rjw
Established Member
I picked my Rolling Stones one up from HMV. MVC had them cheap online.
dave48
Established Member
The future has to be lossless formats - MP3 is c**p for anything other than convenience use since it is throwing away data that represents "real" sound. Nothing to stop you using a PC as the main music source - I use Windows Media Player with a Pro soundcard and it sounds stunning. If you want to save disk space, something like Monkey's Audio Compression is a possible way to go.
Dave48
Y
Yummy Fur
dave48, I think you're right..... pretty pointless throwing away source material, then spending a fortune to reproduce what's left!
I said earlier-
Of course I meant to say CD's & SACD's.... , I'm sure you were all smart enough to spot my mistake, but far to polite to point it out :D
Yummy Fur
alexs2
If you cant tell the difference between CD and SACD,and also think the future of music etc lies with MP3....then either you haven't heard them all on a suitable system,or you really enjoy lo-fi home theatre.
E
eddiea
Len
I've got about a dozen SACDs, and do not intend to buy any more as I do not think a product that is only available on the internet or by post will ever take off, yes there a few titles in the shops but not on a dedicated display and the average record shop assistant has never heard of SACD.
Some web sources that I have used are as follows, good luck.
www.euphoricsounds.com
www.amazon.co.uk
www.superaudio-cd.com
www.telarc.com
www.highfidelityreview.com/reviews/sacd.asp
www.elusivedisc.com
http://interprod5.imgusa.com/son-403/i_Searchpage.asp
L
Len
Thanks Eddiea
That is exactly what I was looking for.... Shame I had to wade through so much pap about MP3s :)
⭐ Philips OLED+908 TV preview + REL subwoofer and Avid Accent amplifier reviews + Hi-Fi & AV News
Back
