Sacd
Discussion in 'Home Cinema Buying & Building' started by DDDavo, Jun 3, 2004.
  1. DDDavo
    DDDavo
    Firstly not sure where to post this thread but i'll pop it in here because i'm reffering to my Davs 550 (all in one.)
    Basically, i own this system and it supports SACD, something i've never tried. Where can i buy super audio disks from? And what is the difference between our standard audio CD's and these super ones?
    :confused:
    Thanks a lot
    Dave
  2. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    I'm sure those more technically minded will give you in depth appraisal, but in simple terms the main difference is multi channel (5.1) music. Bear in mind though that not all SACD's are Multi Channel (some are two channel) and a lot of those that are tend to be a little gimmicky; try too hard to emphasise the surround sound effect.
    To my mind a good example of how it should be done is Telarc's infamous 1812. Try the standard CD track, then the SACD multi channel and the overall sound really does seem to go from 2 to 3 dimensional.
  3. DDDavo
    DDDavo
    Hi thanks, had a look round and read an article on net a few mins ago on comparing sacd to dvd audio and standard CDDA. I do fancy trying multi channel audio however there just doesn't seem to be the choice out there! I'll look at that one you mentioned!
    Thanks again
  4. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    If you're looking for information on releases and places to buy, check out my links in this thread.
  5. DDDavo
    DDDavo
    aha, thanks, taking a look now
    cheers
  6. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Amazon have a large selection
  7. DDDavo
    DDDavo
    yep 600 odd! just lookin thanks, although can see it taking a while going through every page!
  8. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Tubular Bells Is good
  9. DDDavo
    DDDavo
    Hi!
    Is this 5.1 or stereo then (tubular bells) as i do wish to purchase an sacd but preferably the 5.1 encoded ones and even more preferred, the hybrid disks.
    http://www.amazon.co.uk/exec/obidos/ASIN/B000057NVH/026-4037051-2218038
    Doesn't really give any info?
    Also, just remembered been reading a bit on dvd audio. Which is better would you say? Really i'd like to try either, but which ever would offer me 5.1 true output rather than stereo.
    http://www.play.com/play247.asp?searchtype=dvdatitle&searchstring=tubular+bells&page=search
    is the link to the DVD audio one
  10. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    Unless you've got something other than the DAV-S550 I'm afraid you're going to have to forget DVD-Audio.
  11. DDDavo
    DDDavo
    oh! Pass on DVD audio then!
  12. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    It is hybrid, multi channel or stereo its claimed even the stereo is better than basic cd? I also have dvd audio
  13. DDDavo
    DDDavo
    so which do you thinks better. I'm going to have to go for SACD (which i intended to anyway) but does it really bring the performance alive?
  14. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Haven't done a back to back with the same disc in each format so couldnt say. both formats are good and I thought there was a good presence with bells. orchestral music would be the best test I'd think
  15. DDDavo
    DDDavo
    great, ok thanks, ill probs buy the SACD tubular bells then and see what i think!
