SACD - Possible on a HTPC?
Discussion in 'Desktop & Laptop Computers Forum' started by Skunkpipe, Apr 19, 2005.
  1. Skunkpipe
    Skunkpipe
    I guess DVD-Audio works on a mediaPC, but what about SACD? Anyone able to play these
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    no, I'm afraid not. The proprietary format is unlikely to be licensed by its owners in a bid to stop piracy of high definition audio :(
  3. Skunkpipe
    Skunkpipe
    :thumbsdow Boooooo:thumbsdow
    Do you know if my assumption about DVD-Audio being supported true?
  4. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    yes, you can play DVD-A on an HTPC but you need a specific soundcard (an audigy IIRC) and the software that comes with it.
    HTH
    owain
  5. Skunkpipe
    Skunkpipe
    :smashin: Cheers Thanks
  6. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    IIRC, SACD can only be be sent over analogue channels, therefore you'd need a sound card with 6 outputs for the 5.1 surround.
    Richie.
  7. MikeFish
    MikeFish
    My DVD/SACD player can send all channels digitaly down a firewire cable straight to my amp to be decoded. Can't go down a optical/coaxial cable as there is just too much information.
    Shame my PC can't play SACD discs, could get rid of my DVD player then.
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    The ability to extract SACD in digital form is a pretty new ability, AFAIK until recently their paranoia prevented them even licensing it for protected connections like iLink.
    They've said they'll never license SACD for PCs, even in a hardware-only form like DVD-A can be done.
