SACD Poor Bass Management : No sub output
Discussion in 'Subwoofers' started by Dolbyz, May 27, 2005.
  1. Dolbyz
    Dolbyz
    On SACD I have no subwoofer playing on SACDs. My subwoofer, a Velodyne CT80, is connected via the LFE (SUB PRE OUT) on the receiver. The SACD player is set to SUBWOOFER : YES - and I've tried all speakers on SMALL and LARGE. I still get no subwoofer output!
    I want to connect my sub to the amp via speaker outputs, and then my speakers to my subwoofer. I'll set the SACD player and my amplifer to SUBWOOFER : OFF, and hopefully get a full range signal through my speakers.
    Will it work as well?
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    I think doing this you'll negate one of the main points of SACD which is to feed the sound to discrete speaker channels.
    Is there a test tone on your player and if so does the sub out work for that?
    Lack of SACD sub output is not an unusual topic, certainly with some hybrid DVD/SACD players. It's a common comment for the Pio 575 'caus the sub out setting defaults to off. It's also a comment made against the Samsung 745 which seems to have a fault on some machine where there' no sub output for SACD...PJ :)
  3. deanym
    deanym
    May 29, 2004
    1,832
    +142
  4. Mandel
    Mandel
    Do SACD player manuals not warn of the sub level being down 10db?! I'd check mine but I got my SACD player without box, manual or remote...
  5. deanym
    deanym
    May 29, 2004
    1,832
    +142
    Perhaps, they should, but mine didn't, hence all the grief I had!! :D
