Itsthesmell
I own a few SACD that I'd love to listen to on my Edge A amp. It looks like the edge can only decode DSD through its USB-b port.
What options do I have to do this because it seems there are no dedicated SACD players that output via USB. So other than using analogue rca leads does anyone have some suggestions?
I'm baffled why CA designed it only to decode via USB.
I own an oppo UDP 203 player, if I set the player to DSD 5.1 through HDMI to the AV amp, but connect the front L+R terminals (rear panel) to the Edge A will I get a full 2 channel sound to the edge A or a diluted form based on the oppo being set to multichannel? I tested it and it seems like 2 channel but I might be wrong.
If I invest in expensive phono leads is this the best way to go?
Thanks in advance
Daz
Thanks in advance
Daz
