SACD play back
Discussion in 'AV Receivers & Amplifiers' started by teddstarr, Jul 23, 2002.
  1. teddstarr
    teddstarr
    Feb 4, 2002
    41
    Hi all,
    I have just bought my first SACD but was a little narked about the sound!!!
    It seems that you can not pass the sound from the player through the equaliser/graphic/bass/treble etc. of the amp??? All you get is the PURE reproduction of the disk,which on my system sounds a little limp(no balls to it).
    Player is connected to amp using digital coaxial lead and 5 phono leads.
    Any ideas?(am i making an obvious error?)
    teddstarr:D
    system:
    Sony strdb 1070
    Sony dvpns 900
    mission m74 surround package
  2. SiFi
    SiFi
    I think this is normal, my Yamaha does that too!
  3. stranger
    stranger
    use six phonos- use the 900s speaker and bass management for setup- use wide range make sure player is set to m/chanel sacd via remote (or2/chanel sacd) disc must be stopped to do this sacd replay is excellent through the 900 when set up correctly:)
