robbobert7
Hi,Hope someone can help.I have just Changed my trusty old DENON avr 1906 for a YAMAHA RX-A830 advantage which has great sound and video.I have a DENON DVD 2910 which i only use for SACDs/CDs.The problem i have is I cannot play SACDs as the YAMAHA does not have the 5 connections my DENON 1906 has.I contacted YAMAHA( please see reply)I have connected from the DENON DVD 2910 via stereo audio to the audio 1 on the YAMAHA and then connected the optical to the yamaha but I cannot play SACD( when I play PINK FLOYDS,DARK SIDE OF THE MOON,track3"on the run"the foot steps should go around the room but they only travel left to right/stereo.)How do I set the denon DVD 2910 to bitstream rather than PCM !
Hi Robert,
Thanks for your email,
As the RX-A820 does not feature a multi channel input as did your old receiver, your best option is to run a Stereo RCA connection from the Stereo Audio out on the DVD player into the Audio 1 Input of the AV Receiver, you would then select this as your input for listening to SACD's.
You could then run a digital audio connection such as Optical, HDMI or Coax to handle the surround sound digital audio from any DVD's you choose to play back, you will need to make sure the players digital audio is et to Bitstream as opposed to PCM to allow the Receiver to do all the decoding for you of the surround sound.
I hope this helps
Regards, Boyd
Yamaha AV Sales Support
--------------- Original Message ---------------
Subject: Product Support
Hi,I need to connect my denon dvd 2910 to my yamaha rx-a830.I only use the dvd player for SUPER AUDIO COMPACT DISC's(sacd) as it has a decoder and the yamaha doesnt.When i connected my denon amp to my denon dvd player I had 5 phono connections between the two to seperate the five channels.( my denon amp didnt have a sacd decoder).At the back of m New yamaha rx-a830 it gives 5 connections for a power amp in !.What connections will I have to make.
For further questions, please respond to this email.
Please note that email attachments are not allowed.
Regards,
Yamaha AV Sales Support.
ref:_00D105HEf._50010Flxf6:ref
Hi Robert,
I hope this helps
Regards, Boyd
Regards,
