sacd help needed
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Chewbacca, Aug 23, 2004.
  1. Chewbacca
    Chewbacca
    Dec 20, 2002
    366
    North Yorkshire
    +5
    Hello I need some help regarding hooking up My Denon dvd 2900 to My Pioneer vsa e06 5.1 amp.
    The problem is this I took delivery of the above dvd player today which I must say that I am very pleased with indeed anyway I connected a coaxial cable from My denon into the back of My amp (digital in) socket and everthing worked fine i.e it was producing 5.1 sound the problem started when I connected the three pairs of rca leads from the dvd player to the pre outs on the amp I played the sacd of the Police and yes it was decoded in 5.1 but I had no control of the volume on the amp infact I have no control of the volume full stop when I use the phono's also when these phono leads are connected and I switch to watching a dvd the sound is decoded through the denon not My amp this may be a simple problem but its bafferling the hell out of Me can somebody help please as I am new to sacd and have never used the pre outs on the back of My amp before. :rolleyes:
    Just one other thing I have read the manual over and over again and every thing seems to be set up right.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    Well it sounds to me like you are getting your outputs & inputs confused!
    I am unable to check the specs of your Pioneer as I can't find an online review, so does your recevier have 5.1 analogue inputs? If not then you are not going to be able to get multichannel SACD playback via this receiver.
    The pre outs are for useing the internal processing of the receiver to drive external amps.
    Mark.
  3. Chewbacca
    Chewbacca
    Dec 20, 2002
    366
    North Yorkshire
    +5
    Thanks Matey
    My amp does not have the inputs you where on about just the pre outs thanks for the info I understand now where I was going wrong.
