SACD + DVD-A + Upscaling with no Macroblocking
Discussion in 'Blu-ray & DVD Players & Recorders' started by HenryHonda, Jun 5, 2005.
  1. HenryHonda
    HenryHonda
    Nov 13, 2000
    407
    Norfolk
    +39
    Tall order perhaps!
    Anyone recommend a player that can support both audio formats, can upscale to at least 1280x720 (and preferably 1920x1080) with no macroblocking (Denon 2910 reports don't look good!), with HDMI/DVI interface and good picture quality?
    Or is this asking too much at this stage in HiDef development!
  2. chantrys
    chantrys
    Apr 11, 2005
    274
    +9
    Try the Marantz DV-9500. Should be more than capable of satisfying you in each of these areas. I'm picking mine up next month.
  3. Geesus
    Geesus
    Dec 23, 2003
    2,229
    116
    +700
  4. zoro
    zoro
    Jan 23, 2003
    324
    +7
    Pioneer elite 59avi, in that class, in lower class look at samsung
  5. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    marantz dv-9500 fits the bill perfectly.
    The marantz though only upscales to either 720p or 1080i.
    DVD players are not responsible for screen resolutions!! such as 1280 x 720, that is really down to the display device i.e plasma,lcd etc or if you are lucky an external scaler.
  6. HenryHonda
    HenryHonda
    Nov 13, 2000
    407
    Norfolk
    +39
    Thanks all for your contributions...
    Kumamoto - I'm aware that players aren't linked directly to screen resolutions but, if you consider that 720p in 16:9 aspect ratio infers a resolution of 1280x720 (as per EICTA), then some sort of horizontal 'down-scaling' will need to take place in the display to fill say a new Panny 37" PV500 - which has a native resolution of 1024x720. Better that the scaling happens at the player end with a high quality scaler (e.g. DCDi) than at the display end.
    Of course, life would be a lot simpler if PDP manufacturers made panels with perfectly square pixels at least to 720p aspect - therefore, no scaling required!
  7. rockhard
    rockhard
