SACD cables?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by kiddi, Jan 2, 2004.
  1. kiddi
    kiddi
    what cables do you use to connect the sacd player to the amp. Is it just 3 sets of rca cables or something else??
  2. Exeter Man
    Exeter Man
    kiddi,
    Yes - 3 stereo interconnects, or 6 individual ones.
    Regards
  3. kiddi
    kiddi
    thank you!
  4. maia
    maia
    Oct 15, 2003
    101
    Porto
    +4
    What about Optical or Coaxial? U wanna go with RCAs?
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Unless you have the Pioneer DVD & receiver with firewire link then RCA is the ONLY way to get SACD (& DVD-A).
    Optical & coax do not carry the SACD data as it can only be decoded on the DVD/CD player and not by any AV receiver (except as mentioned above).
    Mark.
  6. braincapers
    braincapers
    Jan 2, 2004
    35
    Does this advice apply to DVD-A? My problem is this. I have just bought a set of speakers and moved from listening to DVDs in stereo to surround. All is is fine except when I play my DVD-A (and yes my Marantz is a DVD-A player) the Pro logic symbol comes up on my Yamaha AV & I don't get surround, or particularly decent quality. I've tried digital and 6 channel. Any tips?
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Yes, this does include DVD-A
    To get the full DVD-A sound you need 6 RCA analogue connections from DVD to AV amp. Set the DVD to output 6Ch analogue and the AV to External input (6Ch analogue).
    My 3802 does try to output a DPL2 signal if I forget to set the DVD to analogue output or external input on amp.
    So to get a DVD-A to play I do the following:
    Set DVD to output 6ch analogue from players audio setup menu
    Set DVD-A disk to play DVD-A (instead of DTS or stereo) from disk menu
    Set 3802 input to 'Ext in'
    Sit back and anoy the neighbours :devil:
    It is a lot of playing around to get a DVD-A to play correctly, but well worth it IMHO.
    Mark.
