SACD and DVD-A cables
Discussion in 'Cables & Switches' started by MS-Yam, Sep 21, 2004.
  1. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    My new DVD player has SACD and DVD-A and I would like to connect it to my amp. I understand I need 6 phono cables? Is this correct?
    Can anyone recommend any decent cables around £20? I can stretch to £30 if I will benefit a great deal. Most of my cabling is Profigold which I am very happy with. Which Profigold cables would I need for SACD and DVD-Audio?
    Do any companies do cables specifically for this job or is just a matter of using any 6 phono leads?
    Any help much appreciated!
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Just use 6 Profigolds dude excellent cables IME. Colour code them with different colours of tape to identify them if you want, thats effectively what your paying for when you buy a 6 channel set IMHO. an excellent site for Profigolds I have found, if you want to splash out on cables check out the £7 Digital 1.5m Coaxial lead on that site I bought 2 as a subswoofer cable.
    www.tvcables.co.uk
