S97/1910/HD945/SD Prog Scan
richjthorpe
Hi all,
Which one do I get ? I have a 32" LCD tv with 768 horizontal lines that I want to make full use of and DVI-I socket. The players I'm looking at are the Panasonic S97, Denon 1910 and Samsung HD945. All these can be got for £200 or less. Or even do I get a decent Prog Scan DVD player over component because the DVD players with upscaling aren't up to it yet ? If this is the case, which SD DVD player do you suggest for about a £100 ?
Any ideas ?
Thanks,
Richie.
P
ptoboley
Also consider the Samsung HD745, which it would appear is the same as the 945, only with a DVI out rather than HDMI (945).
richjthorpe
Hehehe, thanks for that but I'm trying to get the list smaller, no increasing it ! :D
Cheers,
Richie.
