S4 Screen Protector, which one
Discussion in 'Mobile Phones Forum' started by petrolhead, Feb 6, 2014.
Tags:
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,910
    87
    Newcastle
    +125
    There are so many screen protectors, especially on ebay
    I know you can get the glass ones but they do seem a tad expensive
    I after a clear, not matt, screen protector which will help stop scratching and also help the screen getting cracked
    Which one would you advise
  2. jian
    jian
    Aug 31, 2001
    2,576
    68
    +77
    Glass from eBay.
    It's only expensive if you buy the ridiculously priced branded stuff.
    In most cases, the branded glass is the sane as the unbranded and most likely came from the same factory.
    And even if this were not true, is a £25 one that much better than a £5 jobbie? The companies that charge more than £10 are laughing all the way to the bank.
  3. Sve
    Sve
    Feb 2, 2014
    3,334
    +827
  4. alextodd
    alextodd
    Sep 7, 2013
    24
    3
    I go with Sve on this, screen protector films are cheaper, reliable and they last with you several months, and even for years if you don't have rough usage.
  5. mustafahaseeb
    mustafahaseeb
    Dec 7, 2013
    165
    lees
    +11
    The best is a glass screen protector I bought mine for 5 pound on ebay and easy to fit compared to normal screen protectors
  6. smacky2007
    smacky2007
    Feb 4, 2010
    726
    +34
    oops just noticed its a very old thread
    i am not particularly a fan of glass , however if you want to buy a standard one... tuffskinz are pretty good on amazon
  7. Professor Chaos
    Professor Chaos
    Aug 30, 2005
    2,547
    +186
    link please?
  8. sirmacdoff
    sirmacdoff
    Nov 22, 2013
    225
    +8
    the anker ones are superb, comes with a nice piece of kit for cleaning up the glass before fitting.
