S video vs PC Input on LCD TV
Discussion in 'Desktop & Laptop Computers Forum' started by scrapbook, Oct 17, 2004.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,189
    +546
    Just looking at a small LCD screen for TV in the bedroom that will also double as a PC monitor.
    The LCD I was looking at doesn't have PC input, although it does have s-video input.
    Assuming I have a graphics card with s-video output are they any differences/disadvantages of using s-video over PC Input?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    S-Video will give a less well defined and sharp image due to the way the separate colour signals are multiplexed, whereas with VGA they're kept separate. How good an image you'll get will depend on the card and the TV, the biggest problem you may find will be that fonts can get hard to read due to the fuzziness of the picture.
    It'll be okay for watching DVDs and video in general, not great but watchable, but for 'PC' work you may have problems.
  3. PAH
    PAH
    Jan 29, 2002
    1,129
    48
    +63
    For PC use you really need a LCD that can accept DVI or a standard VGA input, and a PC with a video card that can output the native resolution of the LCD panel. Otherwise the picture won't be as clear as it could be due to how the panel has to scale the resolution. I've found that connecting via s-video or at a non-native resolution is akin to connecting a PC to an average CRT, i.e. fuzzy and more or less unusable for general PC use.
