s video video switching problem
Discussion in 'AV Receivers & Amplifiers' started by paulefox, Feb 19, 2003.
  1. paulefox
    paulefox
    Feb 8, 2003
    1,293
    Bury St Edmunds
    +43
    I have just set up my amp to use video switching , however it doesnt automatically change the screen size on my TV . Scarts put the screne to the correct size for the broadcast.
    Is there something I am doing wrong
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,840
    Somewhere in South Yorkshire
    +5,067
    Probably not.
    There are two ways that a TV can be 'told' what ratio to display. One is via one of the pins in the SCART setup. The other is by a bit of data that is included in the TV signal (on one of the unused lines at the top of the picture - line 23 IIRC for PAL; line 21 IIRC for NTSC).
    Clearly, by not using SCART you defeat the first method.
    Some TVs CAN interrogate the 'flag' - others don't have this feature. Some can see the line 23 (PAL) flag, but can't see the line 21 (NTSC) flag.
    Personally, I don't find manually switching ratios to be too much of a chore. It's (IMHO) more than compensated for, by the convenience of amp switching. And, in any case, there are a few DVDs out there where the encoding is incorrect, and results (in an autoswitching scenario) in the wrong aspect being displayed anyway.
  3. paulefox
    paulefox
    Feb 8, 2003
    1,293
    Bury St Edmunds
    +43
    thanks
