S-Video to oldskool-SCART opinions.
Discussion in 'Cables & Switches' started by f0rmula, Apr 27, 2007.
  1. f0rmula
    f0rmula
    I have a S-Video connector on the front of the TV, but not on the back; I only have SCART sockets on the back. When I connect the TV-out (s-video) on my PC to the front, it works fabulously. Amazing quality, but I don't really want cables sticking out the front of the TV.
    I tried to convert from S-Video to SCART last night and ended up with a black and white picture. That might not be a suprise to some of the more well informed of you :)
    From http://en.wikipedia.org/wiki/S-Video
    "Most SCART-equipped televisions or VCRs (and almost all of the older ones) do not actually support S-Video, resulting in a black-and-white picture if such a connection is attempted, as only the luminance signal portion is usable."
    "A hack exists to possibly attain color on devices that do not support S-Video through SCART. This is done via joining the pins 15 and 20 in the SCART connector (either directly or using a 470pF capacitor), but may not yield optimal results.
    A similar hack also allows color. This connects the Y and C (3 and 4) pins on the S-Video connector."
    My initial thought is to try and perpetrate the 'hack'. Although, if it's going to ruin the superb quality picture I'm getting though the s-video connection. I'm not sure if that's a good plan. At the moment I'm seriously considering hacking my s-video cable to bits and drilling through the base of the TV to feed the svideo connection in while keeping the frontpanel shut.
    (The TV is a Sony Widescreen http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160106626835)
    What would you guys do about this?
    Cheers,
    James
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    One of the SCART sockets may well be S-video compatible; you could use an operator manual to find out (maybe downlaodable somewhere).
    For the benefit of others, it's a 10 year old Sony KV-28WS2U TV.
    Chris Muriel, Manchester
  3. ows90
    ows90
    Jun 19, 2006
    322
    28
    +60
    Try the scart socket labelled 2 on the back, if s-video is supported that's usually the one that supports it -- and make sure you cycle through all the inputs using the input source button.
  4. f0rmula
    f0rmula
    Oh, sorry. I didn't know the model of TV would matter, I just assumed all of my SCART sockets were incompatible with s-video.
    I'll have a look for a manual for it.
    Thankyou.
    James
  5. f0rmula
    f0rmula
    Nope. Neither SCART socket is S-Video compatible.
    I think I'm going to have to solder a fly lead off the terminals that goto the front svideo socket, and run the cable out the rear.
    James
  6. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,918
    2
    The Fylde Coast
    +13,617
    If you are going to solder stuff, and if your PC card supports the resolutions and timings, why not make a VGA to Scart lead adapter and use the RGB output?
  7. f0rmula
    f0rmula
    Can I do that without damaging the TV/Videocard?
    And does it not matter that it's not a 100hz TV?
    James
  8. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,918
    2
    The Fylde Coast
    +13,617
  9. f0rmula
    f0rmula
