S-Video to Component
Discussion in 'Cables & Switches' started by cominatcha, Oct 19, 2005.
  1. cominatcha
    cominatcha
    Sep 21, 2004
    155
    +3
    I'm looking for a S-Video to Component connector.....does anybody know if there are any converters available ? Do they exist...this link shows sort of what I'm looking for http://www.bizrate.com/buy/noncat_prod_details__oid--332783107.html .....got a feeling these are not available !!
    I'm looking for a straight converter rather then a video switcher if possible.
    Basically its to convert my s-video (from my HTPC) into component (Which goes to my amp) and the amp will send this signal to the projector. I'm just trying to avoid running a 10 metre s-video from the projector to the amp !! Thats if I can !!
    Can anyone help.... :smashin: :thumbsdow :confused:
    Rocky
    Many Thanks
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,551
    Windsor
    +1,056
    vga-component might be easier to find.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,979
    The Borders
    +3,592
    cominatcha
    Why would you want such a mangled video single arriving at your Projector???
    As richard_plump says surely you must have something better than S-Video coming out of the PC - and best to connect the PC Direct to a suitable Input on your Projector.
    Again as richard_plump says if you have to switch everything via your AV Receiver best to install a Graphics card in your PC that can Output YUV 'Component'.
    Best regards
    Joe
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,551
    Windsor
    +1,056
  5. cominatcha
    cominatcha
    Sep 21, 2004
    155
    +3
  6. cominatcha
    cominatcha
    Sep 21, 2004
    155
    +3
