s-video through scart?
Discussion in 'TVs' started by gbmitie, Jan 7, 2005.
  1. gbmitie
    gbmitie
    Apr 25, 2001
    1,120
    48
    republic of ireland now
    +56
    i have a technics dvdplayer that outputs on s-video using the usual 4 pin din connector. However, if i buy a tv that does not have a s-video din socket but does have a scart socket that takes s-video can I buy an s-video lead that has the din plug at one end and the scart at the other? I dont like the idea of having to get an s-video to scart converter as i hate too many joins on a lead.
    gbmitie
  2. scooby do
    scooby do
    Dec 11, 2002
    1,765
    48
    +37
    Should not be a problem, you could even cut the din connector of your current s-vid lead and solder the scart on the cable. Scart shells can be bought for 99p from Maplin
  3. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,368
    Stevenage, Herts
    +151
    Yes there are s-video to scart leads - I have and use one.
  4. gbmitie
    gbmitie
    Apr 25, 2001
    1,120
    48
    +56
    thanks for replies. I looked at profigold site and they have a 5 metre one. I was looking at a jvc tv that has 3 scarts one for s-video hence my question. Sorted now.
    gbmitie
  5. Igwiz
    Igwiz
    Dec 12, 2004
    35
    Hi all,
    I have a similar question in that I have an X-Box cable that ends in S-Video/audio connectors (and a digital audio which I connect to the amp). The Tosh S-Video input is on the front but it does have an s-video enable scart on the back which means I could keep it always connected. Is it as simple as getting a scart adaptor that you can plug the s-video din into. I have the same situation with a gamecube cable the justs uses cinch plugs and I already have a scart/cinch "adaptor" (I think it origally came with a video camera!).
    Many thanks,
    Ig
