S-video Support
Discussion in 'Plasma TVs Forum' started by sevans2626, Apr 27, 2005.
  1. sevans2626
    sevans2626
    Dear All
    I am a newbie to the AV forums. Can I just say thanks to the administrators I found the archives of this site very informative when buying my plasma.
    I have recently purchased a LG 42PX11
    I know they are not the best or the worst butam very happy with it. I want to run my xbox through the s-video connection but the screen will not receive a signal. The input I am using has red/white/yellow and s-video inputs. Sound is fine as well as the yellow composite input but when I take out the yellow composite to use the s-video cable no signal. Is there a menu that I need to access to say use this input instead of the other? I have had a look through the instructions but they are very badly translated and there doesn't appear to be any relevant information.
    I hope you can help...
    Best Regards
    Sam :)
  2. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    If the input on the TV is sharing the s-vid and composite terminals, then yes it's pretty likely that there will be an option somewhere to choose between the two. My old Toshiba RP has a similar thing, AV3 is AV SCART & S-video shared, and I need to switch between AV & S-video depending on what I plug into it.
    Sorry I can't be more specific...just guessing really ;)
    But I'm sure there will be some kind of "connection" or "input" menu somewhere to configure this.
  3. sevans2626
    sevans2626
    Thats what I thought. Anyone know how to access this hidden menu? I heard if you hold menu on the monitor and remote it accesses a new menu. Dont really want to play with it too much as its still new?
    Thanks danluton
  4. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    I'm sure it wouldn't be a 'hidden' menu...I suspect what you are referring to is a service/engineer menu, it's extremely unlikely to be hidden in one of those!
  5. Daddy k
    Daddy k
    Jul 19, 2004
    9,081
    coventry
    +1,345
    if your using the svideo and composite connections on the side then you can only have one connected!
    these are more a temp connection rather than dedicated, use the s video at the rear thats what i have my dvd connected too with the probs
  6. sevans2626
    sevans2626
    Yeah I tried it that way, but it didnt work. Maybe I have a naff lead. I thought the s-video on the back was an output not an input.
  7. Daddy k
    Daddy k
    Jul 19, 2004
    9,081
    coventry
    +1,345
    no mate im defo using the s video at the rear of the panel for dvd!
    i use the side connections (svid, comp)as a quick fix solution ie plugging camcorder in etc,
    so id check ur cables etc and if still no joy id say the panels bust :(
  8. papa_flump
    papa_flump
    Apr 26, 2005
    248
    +8
    I don't know too much about xbox's but this may help...
    "Yeah an Xbox would look better over-all I think if you have a nice TV. If your TV has an S-Video port - make sure you pick up the XBox S-Video adapter cable kit (or a generic one) as it also makes a noticeable difference I found in picture quality".
    judging by the comments above... you may need further kit!
  9. Teccy Toker
    Teccy Toker
    Dec 16, 2004
    68
    There is no hidden option in the service menu for s-video on the Lg...having the s-video cable plugged in overrides the composite video for that av input....also -beware if you are using stiff s-video cables......I was using them on my lg, and i broke both the sockets (just with a slight movment of the cables.)
    TT
  10. sevans2626
    sevans2626
    Had a dodgy lead. Bought a replacement and it works fine. Am using the S-Video on the back not the side and looks great. Cheers for your help guys...
  11. Daddy k
    Daddy k
    Jul 19, 2004
    9,081
    coventry
    +1,345
    pleasure ;)atleast it was the cheapest part that was the dodgy link hey
