S-Video Sky Boxes - do they exist?
Discussion in 'Sky Digital TV Forum' started by TwistedPear, Oct 1, 2003.
  1. TwistedPear
    TwistedPear
    Sep 14, 2003
    20
    Stratford upon Avon
    I'm trying to consolidate the number of inputs into my A/V amp. I have found out that the scart on the back of my Pace Sky box does not support S-Video. What are my options? Can I swap my existing box for a S-Video enabled one? If so, what boxes support S-Video.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    I don't know of any others, but I do know that Sky+ outputs S-Video.
    The other option is to get an RGB to S-Video converter from www.rgbtosvideo.com
    Mark.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    a couple of grundigs do output S-video
  4. yatesd2404
    yatesd2404
    I have a Grundig box, I think it is the 310/2, I can find a link if you need. This certainly has an S Video out and will output on this at the same time as also outputting RGB via the Scart.
    I connect one RGB Scart out to Projector, one Scart to video and then use the S Video to connect direct to TV and works very well.
    Hope this helps, let me know if you can't find box and want to,
    Cheers,
    Dave.
