S-Video RGB Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by bobbles, May 4, 2003.
  1. bobbles
    bobbles
    Firstly is it possible to pass an S-Video signal through a fully wired scart?
    I think it can
    Also
    I now have sky+ connection to my E30 via S-Video and audio leads and I have my S35 connected to my E30 via RGB scart
    So if I record to RAM from sky+ can i then transfer the RAM to -R via an RGB signal?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,708
    Warwick
    +2,584
    Yes.
    Yes as the RGB is just a transmission signal. An extreme example is if you record from a composite VHS source onto a DVDR - you can then play that disk quite happily from an RGB output. The same applies to an S-Video sourced recording.
  3. bobbles
    bobbles
    I can not believe I only just found that out today
    Sorry I didn't word my question very well, what i meant was is there any point?
    in the original recording in RAM using a S-Video connection have you lost whatever made it RGB so would it matter if it was RGB or S-Video when going from RAM to -R
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,708
    Warwick
    +2,584
    Oh I see - I thought you probably knew that Bobbles :blush:
    No your quite right - there isn't much point - you won't gain anything because the initial recording is in S-Video.
  5. bobbles
    bobbles
    the reason I was asking was because I have the S35 set to S-video/Component so i was wondering if it was worth changing to RGB if I was recording from RAM to -R
    Well this saves a little hassle
  6. stevelup
    stevelup
    Aug 13, 2002
    6,511
    Swindon
    +1,086
    Each time you make a copy, the signal will be slightly degraded - using the best possible transmission method will reduce this. Therefore, even if the source was only recorded via s-video, you will reduce the potential signal degregation by making subsequent copies using RGB.
