S-video question
Discussion in 'General TV Discussions Forum' started by Wal, Sep 5, 2001.
  1. Wal
    Wal
    Is s-video as good quality as rgb scart??
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,769
    7
    2
    167
    Birmingham, UK
    +10,673
    In theory, no, but in practise it depends.
    [ 05-09-2001: Message edited by: Spectre ]</p>
  3. Doubledoom
    Doubledoom
    Agreed. It has been noted that older Toshiba models can display s-video at a higher quality than RGB. The current models show little or no difference.
  4. Guest
    I've used S-video and RGB, I find no difference,I've used it on two different set-ups in the past and now still use S-video.<br />It is worth trying both option's,the 2 set-ups I've done,
    Sony32fx65 tv/Sony725 dvd<br />Sony32fx65 tv/LG3350e dvd
    cheers Steve
  5. Napoleon
    Napoleon
    Jan 1, 2001
  6. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    I've always found RGB far superior to S-Video on several different TVs over the years.
    RGB is much bolder and more stable. The colours are richer and more defined.
    The thing about S-Video that fools most people is that the the picture is brighter than RGB and people's faces, especially stand out more. But you will ALWAYS get 'noise' and grain with <br />S-Video which can be seen on closer inspection. Also note the dark shimmering outline around objects none of which is present in RGB.
