S-Video query,help!
Discussion in 'LCD & LED LCD TVs Forum' started by Toby, Feb 10, 2005.
Tags:
  1. Toby
    Toby
    I have a scart lead connected to a sky plus box leading to an LCD display. I have set the lcd to display S_Video yet the picture is black and white with fine lines running through it. Any Ideas?
    Thanks.
  2. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    your trying to send an svideo signal through a scart lead?
    need to use an svideo cable from sky box to an svideo-to-scart adapter if ya wanna use svideo
  3. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Pop into the menu on the Sky+ box. Go to Piture Settings and ensure the output is RGB. Plug the scart into the Sky+ box and into an RGB input on the TV. Usually Ext1 (or 2 on a 3 Scart TV) Set the TV to recieve RGB. Not S-Video.
    Tell me if I've got this entirely wrong and you are actually connecting an S-Video lead.
    Jimmy
  4. Toby
    Toby
    hi thanks for the advice we think thats correct we'l try that today.
